mkv jetta aftermarket aux port
malibu04
Member - Posts: 40
Posted: August 26, 2012 at 8:07 PM / IP Logged
i installed a jvc kd-nx5000 this afternoon in my 09 ketta tdi this afternoon. i did use the can adapter and have the adapter for the steering wheel controls coming in the mail.
my queatiin is, how do i keep the aux port that is in the console? i know i need to order the uk-58 or whatever the part # is for the stereo, but what wire is going to the console?
thanks for the help
malibu04
Member - Posts: 40
Posted: August 26, 2012 at 8:29 PM / IP Logged
sorry for typos, posting from phone
tjtinter
Member - Posts: 6
Posted: August 26, 2012 at 10:24 PM / IP Logged
There is no way to use the factory AUX wiring, with the aftermarket head-unit. There is a Bluetooth adapter available, or another 3mm AUX adapter that plugs into the CD Changer port on the back of the unit. You would have to run the plug along thru the console and out near the factory one. But if you want a "plug in port" like the factory one, there is other options available, but this requires a little more custom work. Whatever you prefer, the wired plug(male) hanging out in the console, or a mounted(female) plug like the factory one.
@lw@yz$uited
malibu04
Member - Posts: 40
Posted: August 27, 2012 at 2:40 PM / IP Logged
thanks tjtinter.  That's fine.  I'll prolly just run the wire into the new "Cubby" under the stereo.  Does anyone know that model # for the preamp wiring harness?  I can't seem to find mine.
malibu04
Member - Posts: 40
Posted: August 28, 2012 at 9:38 PM / IP Logged
anyone know where to get the preamp wiring harness?
malibu04
Member - Posts: 40
Posted: August 31, 2012 at 9:38 AM / IP Logged
nm...i found it, I am going to have a few more questions this weekend when I go to hook up everything else.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
