re audio ctx32001 amp
still_walkin
Silver - Posts: 644
Posted: May 09, 2013 at 6:25 AM / IP Logged
i was checking out this amp and i noticed that it has two power and ground inputs.. has anyone every seen a amp that needs this kind of power. would you wire it up off two distro blocks from the same 12v source or thats a waste any thoughts post your suggestions
http://www./itm/RE-Audio-CTX32001-3200W-CTX-Series-Class-DE-Monoblock-Car-Amplifier-Amp-/290910551244?pt=Car_Amplifiers&hash=item43bb9ebccc&vxp=mtr#ht_2053wt_1170
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
oldspark
Gold - Posts: 4,913
Posted: May 09, 2013 at 7:46 AM / IP Logged
They split one big terminal into 2 smaller ones for size & cable etc reasons. It is not a dual-supply situation - the terminals are connected together in the amp.
still_walkin
Silver - Posts: 644
Posted: May 09, 2013 at 7:50 AM / IP Logged
So your saying the dual power sources is over kill or based on the specs its needed to power this amp
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
oldspark
Gold - Posts: 4,913
Posted: May 09, 2013 at 8:03 AM / IP Logged
Unless it is a dual supply input, a dual power source is pointless.
In fact it will be more unreliable unless EACH source can handle the required power.
still_walkin
Silver - Posts: 644
Posted: May 09, 2013 at 8:15 AM / IP Logged
That's what I was thinking about the dual supply input .
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
oldspark
Gold - Posts: 4,913
Posted: May 09, 2013 at 9:59 AM / IP Logged
I can't see the need for a dual (redundant) supply for amps - they are not telco equipment.
And the cost involved - for something that rarely occurs...
It'll probably be like the Kicker I dismantled - parallel terminals onto a common PCB track - merely to make connection easier or maybe a redundant terminal for half the cable voltage drop. But not a "dual" supply - merely dual feeds.
DYohn
Platinum - Posts: 10,741
Posted: May 09, 2013 at 10:23 AM / IP Logged
Dual power inputs? Not according to this picture:
Photo from RE Audio
oldspark
Gold - Posts: 4,913
Posted: May 09, 2013 at 10:55 AM / IP Logged
And that's only 90A - NBD (no big deal).
still_walkin
Silver - Posts: 644
Posted: May 09, 2013 at 2:35 PM / IP Logged
That's the point I'm getting at . I'm thinking dual inputs is this really necessary or its one of thosd things or angles some companies use to sell there equipment. At first I'm thinking that would look cool under a amp rack with 4 giant wires running to it but then I go . 12v is 12v unless it was from two different sources . So I decided to ask . Ultimately I might just email the company and ask
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
DYohn
Posted: May 09, 2013 at 5:01 PM / IP Logged
The only possible purpose of "dual inputs" would be to use two smaller gauge cables to achieve the current carrying capacity of a larger gauge. There is no other purpose in a 12V system. That being said, the amp you mention in the title has ONE input, according to the photo from RE.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
