Posted: May 15, 2003 at 11:50 PM / IP Logged
Posted: May 15, 2003 at 11:58 PM / IP Logged
Posted: May 16, 2003 at 12:31 AM / IP Logged
Posted: May 16, 2003 at 4:54 PM / IP Logged
Posted: May 20, 2003 at 7:50 PM / IP Logged
Posted: May 20, 2003 at 9:14 PM / IP Logged
Posted: May 21, 2003 at 9:30 PM / IP Logged
Posted: May 21, 2003 at 10:21 PM / IP Logged
Posted: May 21, 2003 at 10:26 PM / IP Logged
Posted: May 23, 2003 at 1:25 PM / IP Logged
Tuesday, May 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
If you got another 2ohm DVC sub then you would wire them like this into your existing amp at 2ohms...
If you got a 1ohm stable amp, then the proper way to wire your existing sub into a 1ohm load is like this...
Your last option depends on if you can exchange the sub for the 4ohm DVC version (you never did mention what sub you are using). If you could do that, then you would wire it like this for a stable 2ohm load...
