vacuum enclosures
maoskeeter
Member - Posts: 9
Posted: June 08, 2015 at 12:01 AM / IP Logged Link to Post Post Reply Quote maoskeeter
I've heard some conflicting arguments about whether there is an advantage to pulling a vacuum on a completed enclosure. From a perspective of making sure your enclosure is sealed it could make sense, but i wonder if a sub would perform differently in a state of vacuum. . I'm new to this forum and a rookie in car audio, so go easy on me if this is the dumbest thing you've ever heard of. If there is any benefit to this, I'd like to know why.      thx,   Mao
DYohn
Moderator - Posts: 10,741
Posted: June 08, 2015 at 11:45 AM / IP Logged Link to Post Post Reply Quote DYohn
A vacuum? Do you mean creating an air-tight enclosure and then somehow sucking all the air out of it? No, this would be a very bad idea indeed, and would in fact be impossible with many woofers. The air inside the enclosure is an integral part of how a loudspeaker system works.
icearrow6
Copper - Posts: 497
Posted: June 08, 2015 at 7:28 PM / IP Logged Link to Post Post Reply Quote icearrow6
Sound is a series of pressure waves. These waves need a medium to travel through.
Nothing to travel through, no sound. AkA -"in space, no one can hear you scream"
Besides you would destroy the woofer as the atmospheric pressure tried to fill the void.
as for the "theoretical" sound if the woofer could sustain the vacuum? Well, the amount of energy to mechanically move the woofer would be enormous. So i would expect the woofer to not even move at the rated power.
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
