distribution block advice
pts760
Copper - Posts: 403
Posted: August 01, 2015 at 1:59 PM / IP Logged Link to Post Post Reply Quote pts760
im looking for a distribution block that does both power and ground for space and cleanliness reasons. i found one that tspec makes V12DB-14PN but i want to see my other options. also does someone make a adapter that would allow my 4 AWG wire to go into the 0 AWG slot or do i have to make something.
basically i need one 4 AWG in and (2) 8 AWG out for power and ground. im installing a soundstream st1.700d and a soundstream st4.1000d. anyone have experience with the dual polarity d-blocks.
I drink current, eat ohms, and bleed voltage
DYohn
Moderator - Posts: 10,741
Posted: August 03, 2015 at 8:36 AM / IP Logged Link to Post Post Reply Quote DYohn
You should only use distribution blocks for power. Make your ground connections as short as possible directly to the chassis near your mounting position.
pts760
Copper - Posts: 403
Posted: August 03, 2015 at 9:26 AM / IP Logged Link to Post Post Reply Quote pts760
I'm sorry but I don't agree with that. If I'm running a 4 AWG to (2) 8 AWG for ground in order to power (2) low current amps (30 amps each) there will be plenty current flow and the install will look cleaner
DYohn
Posted: August 05, 2015 at 11:12 AM / IP Logged Link to Post Post Reply Quote DYohn
Disagree all you like. But you're still wrong. :) If all you care about is looks then do whatever you want. I'm more concerned with proper performance.
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
