Pink Noise
allthedbz
Posted: July 20, 2016 at 10:19 PM / IP Logged Link to Post Post Reply Quote allthedbz
What is the difference between correlated and uncorrelated pink noise?
I Learn Every Day
tonanzith
Gold - Posts: 603
Posted: July 21, 2016 at 2:35 PM / IP Logged Link to Post Post Reply Quote tonanzith
Stereo pink noise is 'uncorrelated'. Therefore it is not associated with the pink noise on the other channel. This minimizes problems with standing waves, etc. Mono pink noise does not share this attribute. This is easy to test. Play stereo pink noise and try to set your time alignment. You can't. The reason is that the left and right speakers must have a similar signal for us to compare the distance between them based on time differences. We will place the soundstage using SPL with stereo pink noise. Mono pink noise has the same signal through both speakers at the same time so we can compare the time differences between the two sources. Therefore, we can hear the soundstage moving across the vehicle with mono pink noise while changing the TA settings on our processors. Basically we set frequency response using uncorrelated (stereo) pink noise. We set time alignment by ear using correlated (mono) pink noise. (bold emphasis mine)
Gary Sather
allthedbz
Posted: July 21, 2016 at 7:20 PM / IP Logged Link to Post Post Reply Quote allthedbz
Thank you for the reply! Very helpful.
I Learn Every Day
allthedbz
Posted: July 21, 2016 at 7:24 PM / IP Logged Link to Post Post Reply Quote allthedbz
Sorry, I forgot to ask but seeing as how this question pertains to the same topic. In what order is it best to set frequency and time alignment. I would assume it best in that order, or rather would it be better to set the time alignment first?
I Learn Every Day
tonanzith
Gold - Posts: 603
Posted: July 21, 2016 at 7:36 PM / IP Logged Link to Post Post Reply Quote tonanzith
Personal preference but I do time alignment last.
Gary Sather
allthedbz
Posted: July 21, 2016 at 7:45 PM / IP Logged Link to Post Post Reply Quote allthedbz
i think i would do the same. thanks again
I Learn Every Day
Thursday, October 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
