Tap into sup harness Ford / Sony
jasonz28camaro
Posted: February 24, 2017 at 9:42 PM / IP Logged Link to Post Post Reply Quote jasonz28camaro
I hooked up a high low converter in my wifes 2014 Explorer sport with the sony 12 speaker system the other day and I went off the left and right rear speakers after the factory amp to run my aftermarket amp and sub. I do not really like how it sounds and I wanted to try to go off the sub harness wires after the amp instead. My problem is its a dual voice sub and has 4 wires. I do not know what wires are what and i cannot find a diagram anywhere to save my life.
my converter has left and right speaker hookups 4 wires total. Need to know were to put the left +/- and right +/-.
The sub wires coming out of the amp are:
Yellow
Green with purple stripe
Grey
Purple
I have seen some of the F-150/F-250s hooked up this way but they seem to have different color wires then mine.
Jason
soundnsecurity
Gold - Posts: 2,720
Posted: February 25, 2017 at 7:55 AM / IP Logged Link to Post Post Reply Quote soundnsecurity
the best thing you can do is just use one side, and make sure to disconnect the factory sub because it will most likely just hurt the overall sound to have two different sub woofer systems playing at the same time. the factory sub is dual voice coil but it should only be one audio signal going to it so it shouldnt make any difference because it will still be a mono signal
