jl audio 250/1 power problem
wspenc83
Posted: June 04, 2017 at 5:39 PM / IP Logged Link to Post Post Reply Quote wspenc83
I have a JL audio 250/1 amp that has worked perfect for the last 13 years and has not been used for the last 3 years. Went to turn the stereo on and heard the subs pop and noticed the green power light would be on and then turn off about every 4 seconds and the subs would suck back into the frame when the green light was on. Checked all the wiring, put new batteries in and even removed amp and installed in a friends car to double make sure and still did the same thing. Anyone had this happen before or have any ideas of what could be wrong?
Platinum - Posts: 13,725
Posted: June 04, 2017 at 6:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
It has shorted output transistors. It needs to be repaired.
wspenc83
Posted: June 04, 2017 at 6:17 PM / IP Logged Link to Post Post Reply Quote wspenc83
Do you think it would be best to send it into JL to fix or try and find a shop around town that could fix it?
Posted: June 05, 2017 at 6:59 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Finding a shop around town is becoming more difficult by the second. Is there a shop in your town that is able to repair it? Have them remove the bottom cover and inspect the clamps that hold the transistors to the heat sink. Ask them how they are going to remove them. If they have that Deer in the headlights look, stop them and I will instruct them on the easy and safe way to remove them.
Helpful Tool
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
