2016 Ford F-250 Super Duty Radio Issues
johnnygaloshes
Member - Posts: 49
Posted: July 21, 2018 at 11:38 AM / IP Logged Link to Post Post Reply Quote johnnygaloshes
I have a 2016 F250 with the mid-level AM FM CD player. Not long after I got the truck the Bluetooth stopped working the XM radio still works and the volume still works and all the controls on the radio still work except for the Bluetooth of course but if I try to push Bluetooth to make a call it will not work whatsoever neither will the controls on the steering wheel at all. I'm just curious if anyone suggest whether it's the radio or the sync module under the dash. I hate to buy one from a scrap yard and it be the other. Also does anyone know if I will have to get the system reprogrammed if I buy a new sync module or radio. Thanks for your opinion guys and gals.
Platinum - Posts: 13,724
Posted: July 21, 2018 at 11:55 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Remove the ground cable from both batteries for a few minutes. Re connect and let us know if that helped.
johnnygaloshes
Member - Posts: 49
Posted: July 21, 2018 at 11:57 AM / IP Logged Link to Post Post Reply Quote johnnygaloshes
I did that and I also pulled the fuse to the radio and the batteries and I also disconnected the sync module for about 12 hours and the batteries and it didn't help
eguru
Copper - Posts: 340
Posted: July 22, 2018 at 10:17 AM / IP Logged Link to Post Post Reply Quote eguru
The steering wheel controls interface directly to the radio. Since the BT is also not working, I suspect it is the radio that is the source of the issues.
A replacement radio won't require any reprogramming.
johnnygaloshes
Member - Posts: 49
Posted: July 22, 2018 at 11:38 PM / IP Logged Link to Post Post Reply Quote johnnygaloshes
Any idea if my XM Radio ID will change if I change the head unit or is that all programmed in the sync module.
eguru
Copper - Posts: 340
Posted: July 23, 2018 at 8:15 AM / IP Logged Link to Post Post Reply Quote eguru
XM ID is from the radio
