1997 Civic LX Aftermarket Radio/No Dome Light
electro newby
Posted: October 31, 2018 at 8:31 PM / IP Logged Link to Post Post Reply Quote electro newby
I installed a simple JVC radio w/o CD player, and I'm trying to avoid leaving the factory radio hidden in the car. I found a youtube video showing how to jumper between connector pins to get your dome light to work with the door switch and I installed the jumper (pic). Now the ceiling dome light switch has two "on" positions and one off, but does not get switched by the door switch. Also, my electric mirrors stopped working after install. Any help would be appreciated.1997 Civic LX Aftermarket Radio/No Dome Light -- posted image.
electro newby
Posted: October 31, 2018 at 8:32 PM / IP Logged Link to Post Post Reply Quote electro newby
It has two green connectors that were connected to the factory radio. The one with the jumper in the above picture is the smaller connector of the two. It is keyless entry equipped.
Ween
Platinum - Posts: 1,368
Posted: October 31, 2018 at 9:43 PM / IP Logged Link to Post Post Reply Quote Ween
Light Green/Red...door switch @ pin 14, Light Green/Black...dome light @ pin 8. Connect those together.
geepherder
Platinum - Posts: 3,668
Posted: November 01, 2018 at 8:39 AM / IP Logged Link to Post Post Reply Quote geepherder
Ween posted a helpful link a while back. You can lookup wiring diagrams for many vehicles. I suggest you bookmark it:
http://www.bbbind.com/free-tsb
Dome light (under lighting):
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=60030
Power mirrors (under interior and driver amenity):
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=60048
Check fuse 17 under your dash for the mirrors.
electro newby
Posted: November 01, 2018 at 10:52 AM / IP Logged Link to Post Post Reply Quote electro newby
Thank you Ween!!! Worked like a charm.
Geepherder, I will check the mirrors after work. Thanks for the links!
electro newby
Posted: November 01, 2018 at 6:47 PM / IP Logged Link to Post Post Reply Quote electro newby
The mirrors I will have to track down, but I have the info to do it. I have the links in Favorites. Thanks!
