High-To-Low Converter Power?
midalfanger
Posted: November 21, 2018 at 10:12 AM / IP Logged Link to Post Post Reply Quote midalfanger
what up.long time looker.can i jus power my high-to-low converter off my amps power wire?o its a scosche loc2sl.
geepherder
Platinum - Posts: 3,668
Posted: November 21, 2018 at 3:06 PM / IP Logged Link to Post Post Reply Quote geepherder
You can. Also install a fuse inline.
midalfanger
Posted: November 21, 2018 at 3:21 PM / IP Logged Link to Post Post Reply Quote midalfanger
ok here it is.ive never had to use one of these converters.So factory head unit(99 ford contour)scosche loc2sl is tha high low converter.Kicker 1000.1 on a power acoustic 12 walmart special.my problem is i taged the inputs for tha converter from rear speakers,found my 12v constant,grounded it well.Hook up remote to amp.well long short of it is the light on tha amp is like its flashing with tha audio signal.
geepherder
Posted: November 21, 2018 at 11:40 PM / IP Logged Link to Post Post Reply Quote geepherder
Verify that the black/blue wire from the radio is switched with the key. Use that to feed your amp turn on instead of the LOC's output.
Monday, August 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
