Adding Amp to 1999 Toyota Avalon with Factory Amp
lee@loudhouse
Member - Posts: 22
Posted: February 05, 2019 at 5:15 PM / IP Logged Link to Post Post Reply Quote lee@loudhouse
I'm trying to add 2 amplifiers to a 1999 toyota avalon with a factory amp.one 4 channel and one mono amp. along with all new speakers and a sub. no one sells a amp bypass harness or anything. I was wondering if I could just unplug the factory amp and use the aftermarket amps? but will I have to run all new speaker wire to each door or can I just speed wire from aftermarket amp to the new aftermarket headunit. or maybe speedwire from aftermarket amp to factory amp plug to catch all the speaker wire?basically my question is how do I add amps to this 99 avalon with a factory amp?
and if I unplugged the amp will I lose any important features? I'm very confused any advice would be appreciated thank you
loudhouse
Platinum - Posts: 13,722
Posted: February 05, 2019 at 8:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Speed wire from aftermarket amplifier to factory amplifier location. The amplifier in that vehicle is only an amplifier, you will lose nothing if you remove it.
lee@loudhouse
Member - Posts: 22
Posted: February 23, 2019 at 11:11 PM / IP Logged Link to Post Post Reply Quote lee@loudhouse
thank u I was hoping it was easy
loudhouse
Tuesday, October 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
