amp and sub selection
mrtire
Posted: June 06, 2003 at 7:17 PM / IP Logged
I have a 2002 s10 regular cab , I just installed a pioneer premier 940mp and a set of infinity kappa 6.5's in the doors and 4.6 in the dash . My question is I heard a kicker s10l7 and loved it so I was going to buy the enclosed box version which is 4 ohm ,but the amp I wanted is a 600.1 mono class d which runs at 2 ohm .This setup seems not to match up ohm wise  , Should I make another choice.
Thanks Jim
New member
wvsquirrel
Gold - Posts: 1,237
Posted: June 07, 2003 at 1:35 AM / IP Logged
The JBL BP600.1 can run at 1, 2, or 4ohms. It's rated 600 x 1 @ 1 or 2 ohms (it's 1ohm stable but there is no power increase), and 300 x 1 @ 4ohms.
The Kicker S10L7 is a DVC (Dual Voice Coil) sub that comes in dual 2 or 4 ohm models, rated at 600RMS 1200Peak. The BP600.1 amp is a good match for that sub.
If the model you were looking at is the 4ohm version, then you can wire it in parallel for a 2ohm total load at the amp, giving you 600 x 1 @ 2ohms
amp and sub selection -- posted image.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
mrtire
Posted: June 07, 2003 at 5:48 AM / IP Logged
thanks Squirrel
I appreciate your help
Jim
wvsquirrel
Gold - Posts: 1,237
Posted: June 07, 2003 at 8:39 AM / IP Logged
No prob, glad to help
Squirrel
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
