2003 Acura tl install
Bustrbyte
Posted: July 04, 2003 at 6:15 AM / IP Logged
 I am going to install a satellite radio (FM modulator)in my 2003 acura tl. I have no idea how to get the existing radio out. Do you hook up the FM modulator to the radio, or is there an antenna connection in the trunk? Also where would you hook up the 12 v. Thanks very much for any help.
esmith69
Gold - Posts: 1,511
Posted: July 04, 2003 at 2:09 PM / IP Logged
I think all you have to do is pry off the radio trim bezel, and then remove the 4 phillips screws holding in the radio.
The antenna is built in to the rear window but the plug should be in the back of the stock stereo, and it should just be the standard motorola-style plug.  Once you pull the stock radio out, you disconnect the factory male antenna plug, then plug it in to the female antenna connector of the fm modulator.  Then take the fm modulator's male plug and plug that into the back of the stock stereo.
The constant power wire should be yellow, and the switched power wire should be purple;  but you should verify thess first with a DMM before making the connections.  Depending on which satellite system you're getting, you may need one or the other, or in some cases you'll need both.  And the ground connection must be made to the vehicle's chassis--any bare metal mounting bracket behind the radio dash opening should work fine, but test first with a multimeter of course.
Ethan
Donate to the12volt.com
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
