Port lengh
bigmurf127
Member - Posts: 25
Posted: July 07, 2003 at 6:54 PM / IP Logged
I'm looking at this sub from Visonik the V1265S4
it asks for 2 four inch ports that are 19 inches long tuned at 33 herz. IS it me or is that really long.
I used a couple of online calcutators and they say 10" ports, confirmed by 3 calculators.
I don't want to build a box that deep, should i believe manufacturer specs or go with the standard equations
bigmurf127
Member - Posts: 25
Posted: July 08, 2003 at 11:31 AM / IP Logged
bump
red_1
Member - Posts: 9
Posted: July 08, 2003 at 3:41 PM / IP Logged
I would go with the manufacturer specs because it will give you the best sound
tdsteele
Silver - Posts: 393
Posted: July 08, 2003 at 4:11 PM / IP Logged
You can do different things to make it different, for instance, cut your port that length, then when it gets close to hitting the back of the box, cut it off and put a 90 on it. Or depending on the install, leave the excess port hanging out the front of the box. Just has to be the correct length one way or another. Could possible try converting it to a slot port and see what size that would make it.
bigmurf127
Member - Posts: 25
Posted: July 08, 2003 at 9:35 PM / IP Logged
whats the formula to convert from round to a slotted port?
bberman1
Gold - Posts: 2,314
Posted: July 09, 2003 at 9:15 AM / IP Logged
If you convert it to a square port you will still have the same port length. https://www.the12volt.com/installbay/forum_posts.asp?tid=14074&KW=square+port
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
