Wattage loss?
Earkus
Posted: July 08, 2003 at 9:37 AM / IP Logged
I recently applied capacitors to my door and lid speakers to cut off bass below 135Hz.  It seems that since I did this I have affectively reduced my receivers ability to provide full power to my speakers.  I also added a subwoofer to the arrangement.  For the sub I used the RCA jacks labeled rear on the back of my deck.  Now, for whatever reason even when I disconnect the sub my receiver still doesn't play near as loud as it used to.  It still sounds good but it seems to be only 75% or so of what it was originally.  Does anyone have any idea why this has happened?  When I applied the caps I used a volt meter to identify the positive and the negative wires for the speakers.  I put the caps on the wire that when the red lead from my volt meter was applied had the positive millivolt readings.  Someone please let me know if this was way off.  Thanks in advance.
bberman1
Gold - Posts: 2,314
Posted: July 08, 2003 at 9:46 AM / IP Logged
Can you list your entire set up?
esmith69
Gold - Posts: 1,511
Posted: July 08, 2003 at 9:52 PM / IP Logged
Sounds like you verified the speaker wire polarity correctly so that shouldn't be a problem.
The system's volume is independent of whether or not the subwoofer preouts are hooked up, since they are unamplified outputs anyways.  Therefore, if you unhook the sub from the head unit (via the low-level RCAs going to the sub amp), the rest of the stereo system is not going to get any louder.
Depending on the quality of the filters you used, they may be altering the impedence on the amplifier; most likely they're causing an overall increase in the impedence, and thus the speakers as well as the capacitors are offering more resistance to the amplifier.  Therefore, the amp will put out less power.
Sometimes this can be rectified by ensuring you are using the proper crossovers and are using good quality components, but other times this is simply just a reality of using them.  Short of switching to external 4-channel amps and active crossovers, there's not a whole lot you can do.  This is why a lot of people like having the many built-in crossovers in many head units available today, cuz they let you apply cut-offs to speakers in your system without sacrificing sound quality or power output.
Ethan
Donate to the12volt.com
Earkus
Posted: July 10, 2003 at 5:06 PM / IP Logged
I just wanted to say thank you to everyone that replied to my post.  esmith69 I believe that you are correct.  Someone that I work with has confirmed that this may be the source of my problem.  He also suggested that I remove the caps and just turn down the base and allow the sub to supply that and in affect that would do the same thing without sacrificing power.  I will try tonight and let you guys know.  Again thank you very much.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
