fuse relay box for power?
mhollis42
Member - Posts: 7
Posted: July 12, 2003 at 9:32 AM / IP Logged
I have a 98 olds intrigue.  I am setting up my amp and subs.  I was just outside looking where i was going to run the power wire through into my car and I noticed a box labeled "fuse relay center."  This box has a positive terminal on it with an easily removable bolt.  I was thinking that this might be a simple place to run the amp power from but I'm not sure.  Should I go straight to the battery and can I go to the fuse relay center instead?
Mark
bberman1
Gold - Posts: 2,314
Posted: July 12, 2003 at 9:57 AM / IP Logged
You need to go directly to the battery terminal.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
