Kenwood KDC-V6017
pcero
Posted: July 21, 2003 at 1:37 PM / IP Logged
hi, i need to know what are the color codes and the distribution of wires for the factory wire harness for a kenwood kdc-v6017.
for example, this is where the wire harness goes connected but i lost the wire harness and i need to find out wich one is for power supply, left speaker, right speaker, power control, ground wire, ignition wire, battery wire, etc...
[ o o o o o o o o ]
[ o o o o o o o o ]
esmith69
Gold - Posts: 1,511
Posted: July 21, 2003 at 2:24 PM / IP Logged
I really really hope you are not going to solder directly onto the pins of the unit itself!
You can get a replacement harness for this unit and I highly recommend that you do that instead of soldering directly onto the pins on the unit itself.  Try Pacific Coast Parts (product number E30-4940-05) or http://www.installer.com/wires/index.html (product number WH-K16).
Ethan
Donate to the12volt.com
pcero
Posted: July 21, 2003 at 10:01 PM / IP Logged
i already know that. but i live in mexico and im unable to buy it via internet, because they dont send parts outside EUA. and my first idea was to put the wires using some kind of plug and not to solder directly.  thats why i need the order of the wires. and a big THANKS for the url's. Kenwood KDC-V6017 -- posted image.
