Can I hook up 2 comp vr's to a mono amp?
dr_jdelara
Member - Posts: 37
Posted: July 31, 2003 at 12:14 AM / IP Logged
I was wondering if i get 2 12 kicker comp vr's, and i get a kicker class D mono DX700.  Would this amp be enough for these subs?
wvsquirrel
Gold - Posts: 1,237
Posted: July 31, 2003 at 1:03 AM / IP Logged
For 2 CompVR's I'd suggest either...
1) (2) 4ohm 12" CompVR's and (2) KX400.1 Class D mono amps. The subs are 400RMS 800Peak, and the amps are 400 x 1 @ 2ohms. Each sub would be wired in parallel to its own amp, running a 2ohm load per amp. Each sub would receive 400 watts.
2) (2) 4ohm 12" CompVR's and (1) KX800.2 Class AB 2-channel amp. The subs are 400RMS 800Peak, and the amp is 400 x 2 @ 2ohms. Each sub would be wired in parallel to its own channel, running a 2ohm load per channel. Each sub would receive 400 watts.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
dr_jdelara
Member - Posts: 37
Posted: July 31, 2003 at 1:14 AM / IP Logged
just to make sure, the comp vr's you describe are dual VC right at 4 ohms each?
wvsquirrel
Gold - Posts: 1,237
Posted: July 31, 2003 at 1:20 AM / IP Logged
Correct. (1) 4ohm DVC can be wired in parallel for a 2ohm total load. So it would be 1 sub per KX400.1, or 1 sub per channel on a KX800.2
Squirrel
Special-K
Member - Posts: 43
Posted: August 01, 2003 at 3:08 PM / IP Logged
get a audiobahn 1200.1 class d amp.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
