proper grounding for car stereo
ammonzenos
Posted: August 06, 2003 at 12:49 AM / IP Logged
Hi,
I'm having a little trouble with grounding my car stereo that I'm trying to install.  The problem is that a Nissan does not have a ground wire for the stereo, but instead uses its own chasis.  Where and what is the best way to attach the stereo's ground wire to the chasis? tie it down? use screws to tighten together?  Thanks!
wvsquirrel
Gold - Posts: 1,237
Posted: August 06, 2003 at 1:39 AM / IP Logged
You want to screw the wire directly to the chasis of the vehicle. Put a ring terminal (the kind that you crimp onto a wire) on the end of the ground wire and screw it to the chasis of the vehicle. Make sure where you are grounding to is bare metal (no paint, corrosion, plastic, etc). You may have to sand through some paint to make a clean, bare metal contact point.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
ammonzenos
Posted: August 06, 2003 at 3:11 PM / IP Logged
thanks wvsquirrel
wvsquirrel
Gold - Posts: 1,237
Posted: August 06, 2003 at 11:57 PM / IP Logged
no problem
Squirrel
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
