ground wire problem
lancemel
Posted: August 14, 2003 at 2:01 PM / IP Logged
i have a 1991 mercury cougar with a pioneer stereo, which when hooked up to other systems works. the problem is in the ground wire. how can i find where in the ground wire it is located??
ViperATC5
Copper - Posts: 202
Posted: August 14, 2003 at 2:51 PM / IP Logged
The ground wire should be located in the harness in the car - if there is no ground wire, you can ground the unit to any non painted metal surface in the vehicle
