stupid f150 and 1/2 din eq!! need kit
McFord
Member - Posts: 25
Posted: August 14, 2003 at 6:30 PM / IP Logged
ok so i have an 03 f150 and i need an install kit for my full din cd player AND my 1/2 din alpine eq.  For some reason, not one single shop around here has anything that will work.  whats the deal with that??...the metra kit has a built in pocket, that i suppose you could hack off, but when i put a this cd player in my 01 model f150 i had a kit that worked. unfortunantly, when some rat bastards tried to steal my stereo, they broke the kit and i cant use it anymore.  does anyone know what kit i can use to get this overwith??...I dont think the previous kit i had was "vehicle specific" cuz i had to pop rivet the kit to the trim bezel, but even that is fine with me....i just need the darn piece of plastic that is holding me back.  I dont want to have to hack up a kit tho (unless a lasst resort)
someone shoot me some ideas or part numbers or something!
Maxst
Silver - Posts: 866
Posted: August 14, 2003 at 6:32 PM / IP Logged
You could put it in the arm rest..or glove compartment.. or get another kit to put in there.
you try to fix the plastic?
I need quality equipment, feel free to donate.
McFord
Member - Posts: 25
Posted: August 14, 2003 at 6:48 PM / IP Logged
yeah....i got a scosche kit and hacked on it a little......too much modification was necessary to remove the pocket opening, and even then, the fit of the 1/2 din eq was only so so in the opening...it just aint big enough!
McFord
Member - Posts: 25
Posted: August 14, 2003 at 8:53 PM / IP Logged
anyone??......want to get this darn head unit in, so i can get my subs back to workin.....not much fun driving around without some tunes (stock stereo does NOT qualify as tunes.....maybe noise???)
Maxst
Silver - Posts: 866
Posted: August 15, 2003 at 10:42 AM / IP Logged
you could take it to a audio installer and either have them do it....or get you the parts that you need.
McFord
Member - Posts: 25
Posted: August 16, 2003 at 8:51 AM / IP Logged
does anyone know if there is a universal piece i can use or something??
tdsteele
Silver - Posts: 393
Posted: August 16, 2003 at 2:31 PM / IP Logged
I did some searching but turned up nothing. Having it installed at a local shop would be the easiest thing to do. They could probably custom mount it and make a trim plate for the 2 and make it look real nice.
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
