Question about ohms and such
94bonny
Copper - Posts: 108
Posted: August 24, 2003 at 12:38 AM / IP Logged
i am currently looking for the best setup that i would be able to upgrade when i get the cash, i may be stupid but the resistance between the amp and the sub is kinda confusing me.  if i were to get a 2 channel amp that is 400 watts bridged at 4 ohms and 1-4 ohm subwoofer would that setup work? and would it be easy to add a second 4 ohm woofer to that setup?  leave your input thanks
if your interested i was thinkin about getting a infinity kappa perfect 12.1, but im not sure if i would want the DVC or not? help me out please!
Ketel22
Silver - Posts: 976
Posted: August 24, 2003 at 12:46 AM / IP Logged
if you bridge your sub on the amp it will recieve the 400 watts at the 4 ohms but when you add the second sub you need to get another amp or set the subs up so that they run in parallel with the amp, or you can unbridge the first sub and use the channels seperatly. one for each sub, the subs would then be seperated to left and right so be sure to hook that up correctly.
if not enouf ask for more
Quad L Handyman services
94bonny
Copper - Posts: 108
Posted: August 24, 2003 at 12:54 AM / IP Logged
would it be more difficult to hook up a second amp when i add a second sub?  and what do you think about the perfect 12.1 or dvc?
Ketel22
Silver - Posts: 976
Posted: August 24, 2003 at 1:08 AM / IP Logged
the second amp would be better for sound if your budget allots, i am not familiar with the subs. i do mostly wiring. altho depending on the set up of the subs you may want to stick with a single amp using the right and left for sound quality, getting a more powerful amp would be good if you followed this route
94bonny
Copper - Posts: 108
Posted: August 24, 2003 at 1:14 AM / IP Logged
thanks very much, however my budget is limited :(, HS student with a job and HIGH insurance payment :(, so my upgrade could be a while in the making haha, thanks again
