1 amp and one sub
jtfrog
Member - Posts: 16
Posted: August 24, 2003 at 8:38 AM / IP Logged
I am looking to buy a 4 channel amp so i am able to ugrade along the way. For right now i want to do this. The amp I am loking at can run 4ohm in mono and 2ohm in stereo. I would like to bridge the amp to one sub in my 86 vette. So to get the most power do i want a 4ohm or an 8ohm sub and do I want single or duel voice coils
jtfrog
DYohn
Moderator - Posts: 10,741
Posted: August 24, 2003 at 8:41 AM / IP Logged
Get a 4 ohm DVC sub and wire it in parallel for a 2 ohm load.  Connect this to 2 channels of your amp bridged for a mono load, so you have 2 ohm speaker being pushed by a 2-ohm stable amp.  That will leave the 2 other channels on your amp empty.
jtfrog
Member - Posts: 16
Posted: August 24, 2003 at 8:52 AM / IP Logged
Dont I have to get an amp that is stable at 2ohm's . Most amps i see are not stable at 2ohm's unless wired in stereo
jtfrog
DYohn
Posted: August 24, 2003 at 9:10 AM / IP Logged
OH, sorry, I misread your original post.  Going too fast and too early, I guess!
If your amp states it is stable for a "2-ohm stereo" load, then you are correct, it needs 4 ohms when wired mono.  Sorry about that.  So, scratch my original suggestion and go for a 4-ohm sub with a single voice coil and bridge one set of your 4-channel amp into that.  Then if you expand later with a second sub, match the first one and bridge the other two channels to it.
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
