Lightnig Audio Strike large cooling fan
bryceyaworsky
Copper - Posts: 152
Posted: August 24, 2003 at 12:26 PM / IP Logged
Ok, so here's a question for you: I bought this fan and it didn't come with any wiring manual in the box.  It has a red and a blue wire.  Does anybody know what these wires are for?
pureRF
Silver - Posts: 619
Posted: August 24, 2003 at 1:24 PM / IP Logged
They need a 12 volt source. (cig. plug in)
dream it, build it, fiberglass it
bryceyaworsky
Copper - Posts: 152
Posted: August 24, 2003 at 1:39 PM / IP Logged
Well, my best guess would be that the red is the rem turn-on and that the blue is the gnd.  I suppose I'll find out when I hook it up!  Lightnig Audio Strike large cooling fan -- posted image.
DYohn
Platinum - Posts: 10,741
Posted: August 24, 2003 at 7:57 PM / IP Logged
Is this one of their stand-alone fans or one of the fan modules designed to mount on a LA Strike amplifier?
bryceyaworsky
Copper - Posts: 152
Posted: August 24, 2003 at 8:39 PM / IP Logged
stand alone
DYohn
Posted: August 25, 2003 at 8:31 AM / IP Logged
Then the two wires are probably ground and +12V... to tell which is which, hook them up to your battery and see which way yhe fan blows.  If it is with the arrows on the housing, you have it correct.  Use a relay that is activated off your remote power, as in most cases a remote power signal will not be able to supply enough current for a fan.  There is a good primer on relays on this site if you don't understand them, as well as a seperate forum on Relays.
Best.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
