specs for 15 alum eclipse badly needed
pureRF
Silver - Posts: 619
Posted: September 14, 2003 at 7:14 PM / IP Logged
Hey i need the cuft for a sealed box for a 15 Eclipse aluminum for its best performance. thanks a lot
dream it, build it, fiberglass it
Maxst
Silver - Posts: 866
Posted: September 14, 2003 at 8:48 PM / IP Logged
is there not a eclipse site out there? i cant find a thing either. im gonna say 2 to 3.
then again...it should say in the manual for the specs.
I need quality equipment, feel free to donate.
nedgeworth
Silver - Posts: 264
Posted: September 14, 2003 at 9:22 PM / IP Logged
On the eclipse web it isn't stated. But if you send an email to there tech support they will send you there recommended specs.
pureRF
Silver - Posts: 619
Posted: September 15, 2003 at 8:16 PM / IP Logged
I think its stated as 6.2 cuft or somthing weird like that but everyone has said to build them smaller than they specs.
nedgeworth
Silver - Posts: 264
Posted: September 15, 2003 at 8:22 PM / IP Logged
I'd probably say you'd be safe with 3 cuft. But then again i'm no expect on 15's. Maybe bberman1 might be able to help out he seems to be the shall i say guru on eclipse subs around here.
AudioAdrenaline
Member - Posts: 33
Posted: September 15, 2003 at 9:53 PM / IP Logged
The VAS is 6.1 cuft.  The only thing I can find in reference to box size off hand is that they are designed for small sealed enclosures.  For a 15" DVC that generally translates to a 1.5cuft min. box.  But I would still try to find someone who's worked with them before.
bberman1
Gold - Posts: 2,314
Posted: September 16, 2003 at 9:45 AM / IP Logged
Eclipse recommendations:
Sealed SPL .65cu/ft , SQ 1.65cu/ft
Ported 2.0cu/ft with a 5 inch round port 13 inches long.
Now I would suggest that you take the specs above and build some test enclosures with different volumes (.65-1.65) and see which one sounds best to you.
pureRF
Silver - Posts: 619
Posted: September 17, 2003 at 11:54 AM / IP Logged
so if i want some major bass go with the .65 or would the 2.0 with the port put out a TON more bass of just some?
bberman1
Gold - Posts: 2,314
Posted: September 17, 2003 at 4:47 PM / IP Logged
Personally I would go for about 1 cu/ft sealed. I have never put Aluminum in a ported to know how it will sound but I’m sure it will be louder than if it was in a sealed enclosure. But if your going to glass it up I would suggest buying a piece or two of MDF and building some test enclosures and see what volume and box type you like the best. Also if you’re looking for SPL I would take a look at the Titanium’s. They put out huge amounts of bass and still sound good for putting out such an extreme amount of bass.
pureRF
Silver - Posts: 619
Posted: September 17, 2003 at 6:31 PM / IP Logged
yea i was gonna get a titanium but i dont want to stess my cars electrical system. Thats why im only gonna run an amp thats 500 watts and probly not any over. (unless i run an amp to components later) But in a car as big as a 4runner in the inside will one 15 alum in a sealed box put out a good amount of bass? compared to maby 2 Type R's or somthing of the sort?
thanks
