Do they make 150 amp Maxi Fuses?
Dragger817
Member - Posts: 11
Posted: September 25, 2003 at 4:53 PM / IP Logged
I've been searching the net, the highest one  have found is 120, i have a kick zr1000 and the amp requires a 150 amp fuse. I have a Stinger distribution block, and it accepts Maxi fuses only. Thanks for looking!
Quality is the Key to everything!
ViperATC5
Copper - Posts: 202
Posted: September 25, 2003 at 6:32 PM / IP Logged
Go get a new distrobution block that holds an ANL fuse or get a high current circuit breaker
tdsteele
Silver - Posts: 393
Posted: September 25, 2003 at 6:38 PM / IP Logged
Well i had no luck finding one higher than 100 amps and all high power applications i have ever seen use ANL fuses so i dunno.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
