circuit breaker
Ketel22
Silver - Posts: 976
Posted: October 06, 2003 at 7:53 PM / IP Logged
whats the deal with circuit breakers? ive been told you should use them in like with a anl fuse but i see no use in this? does anybody reccomend using a circuit breaker vs an anl fuse block?
Quad L Handyman services
Maxst
Silver - Posts: 866
Posted: October 06, 2003 at 8:28 PM / IP Logged
I think you'd want to use a breaker under high power situations.
I need quality equipment, feel free to donate.
speedwayaudio1
Silver - Posts: 879
Posted: October 06, 2003 at 8:47 PM / IP Logged
breakers make it easy to change thing around in your system. add an amp or cap. all you do is trip the breaker and no power. easy to worrk on. i use them
Big Dave
Ketel22
Silver - Posts: 976
Posted: October 06, 2003 at 10:32 PM / IP Logged
im still in the dark about them?
auex
Platinum - Posts: 5,041
Posted: October 06, 2003 at 10:34 PM / IP Logged
Personally I use a circuit breaker, it is easier to use and cheaper then buying fuses. I have not heard about running both a circuit breaker and an anl fuse inline next to the battery.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
fuseblower
Silver - Posts: 403
Posted: October 07, 2003 at 6:54 AM / IP Logged
There is no real big difference between the both as far as safety.  The high point is convenience, when you blow a fuse you have to get another and take the time to change it out.  With the circuit breaker you just flip the switch and you are back in business.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
