Building custom system need help
Biohazardous
Member - Posts: 6
Posted: October 08, 2003 at 12:28 PM / IP Logged
OK i have built basic systems before  but i have never built one of the magnitude i want to make this one. . . . I dont even know if i can describe the way i want it. . . .lol. . . I want to make the sub enclosures plexi on one side I am goin to put mirror inside and neon. . .then some glass will be involved also but the part i am havin trouble with is my amp rack idea. . . .I would like to have then spin yes u read correctly spin. . . I want them to be on a short stand mounted to like 1/2 or 3/4 plexi with the edges roughed up so neon wil illuminate them  but i want them to spin somehow. . .i have not legistically figured this out yet.. .  so anyone with ideas please reply or even if u have some feedback on my plans let me know. . .I will be gettin this underway hopefully in the next couple of months but i need to plan it all out first.. . . thanx for the help. . .  .
Justin
toadia
Member - Posts: 18
Posted: October 08, 2003 at 12:34 PM / IP Logged
some companies sell sliding door contacts that have a spring loaded pin in one side. you could use that for the amp side.  But you would have to get some blank circut boards and etch perfect circles on the and the solder your wires to that .  you will also need a motor to spin the amps and some electronics knowhow. Not that hard to do if you know what you are doing. But if it is a high current draw anp the contacts might not be heavy-duty enough.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
