98 Chevy Suburban, Delco AM/FM Cassette w/CD Changer
michael853
Posted: October 10, 2003 at 1:06 AM / IP Logged
98 Chevy Suburban - Delco AM/FM cassette radio w/CD changer
wires pulled from connector upon removal
from pins 11 thru 16 on 20pin connector
orange constant 12v, yellow ignition, pink ?
pin 15 & 16 wiring in tact - both are green wires, one g/w other g/b
would like to know pin location for orange, yellow and pink wires- please help
M.Morreale
(845)462-2407
Poughkeepsie, NY 12603
Sweekster
Silver - Posts: 481
Posted: October 10, 2003 at 12:10 PM / IP Logged
Hopefully this will help you out.  I don't know how accurate this but it should help.
Duane...
If you think you're confused, imagine how you feel.   98 Chevy Suburban, Delco AM/FM Cassette w/CD Changer -- posted image.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 10, 2003 at 5:18 PM / IP Logged
Pink is power antenna/amp turn-on, not sure about those GREEN/ stripe wires.
Probably your best bet is to get/borrow an aftermarket radio wire harness, and use it as a guide to where the pins go.
Also, companies like Metra make aftermarket male harnesses that plug into the factory radio, with all the wires color-coded....Best Buy sells them.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
