porting enclosure help
intensem1rider
Member - Posts: 25
Posted: October 12, 2003 at 6:32 PM / IP Logged
ok, i have 3 alpine type-e 12" subs, in 3 separate 1.25 cube sealed enclosures.
Problem is that thay play the high bass notes to much and the lows the barely happen, i want to port my box to get a lower sound but still stay with sound quality.
I only have enough room to fit a 2" wide port paralell to the sub. Can i put the ports 90 degrees to the sub? or perhaps on the back of the box behind the subs? if so then i can get any ports.
But the main prob is chooseing a frequency to tune to.
Jason
bberman1
Gold - Posts: 2,314
Posted: October 13, 2003 at 12:39 PM / IP Logged
How do you have your X-overs set?
intensem1rider
Member - Posts: 25
Posted: October 13, 2003 at 1:35 PM / IP Logged
its not a matter or x-overs, it box.
But anyways the x-over is as 71hz, and the sub sonic is at 15hz, and the boost is set for 40hz.
My amp is the apline mrd-m500, i am an installer at a certified alpine dealer so i know the in's and outs of alpine, just im not a pro at porting, i do know i need to port.
intensem1rider
Member - Posts: 25
Posted: October 14, 2003 at 12:29 AM / IP Logged
anyone?
intensem1rider
Member - Posts: 25
Posted: October 14, 2003 at 12:31 AM / IP Logged
P.S., its not the x-overs, there at 71 and 25
Jason
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
