Visonik amp for my mb subs
Maxst
Silver - Posts: 866
Posted: November 01, 2003 at 8:10 PM / IP Logged
ok thezeb has a visonik V400HC amp on special for 140,
i would like to know if it'll be the right amp for my two MB quart 12" 3 ohm single voice coil 150RMS subs.
Im planning to wire in parallel.
heres link to amp...its the first on the top left.
http://www.visonikcaraudio.com/sub/products/amplifiers_highcurrent.html
I need quality equipment, feel free to donate.
DYohn
Platinum - Posts: 10,741
Posted: November 02, 2003 at 9:09 AM / IP Logged
It says it is stable at 1 ohm bridged, so go for it.  You'll be running 1.5 ohms so it will operate safely within the amps capabilities.
Visonik used to make pretty high quality equipment, but I haven't seen any of their stuff in action for about ten years...
Maxst
Silver - Posts: 866
Posted: November 02, 2003 at 11:11 AM / IP Logged
so this is the right amp for the job? Not overly powering...course i have to remember that im not putting out 14.4 volts...so it should.
thanks for your help.
anybody use(d) their amps?
