passive crossovers hookup
Quick
Member - Posts: 17
Posted: July 20, 2002 at 10:28 PM / IP Logged
I ran across this passage in an article and have a question about it:
With the use of passive crossovers, you can drive a woofer, midbass, midrange, and tweeter or more in parallel on each channel of an amplifier and maintain a safe load (impedance level) on the amplifier across the entire frequency range. Each of these loudspeakers receive a particular range of frequencies determined by one of three crossover filters: low pass, high pass, and band pass.
can someone explain to me if this means if i use a low pass crossover on my sub amp ican get the lower responses im aiming for....and do i crossover before th amp(between amp and head unit) or between amp and speakers  seems like it would be the former but im not sure
GlassWolf
Copper - Posts: 365
Posted: July 21, 2002 at 12:03 AM / IP Logged
with a passive crossover network (built with non-polarized capacitors and coils) they are connected to the speaker terminals, between amp and speakers. They have to be built to the frequency and impedence desired or required.
using a low-pass filter on the subs is always a good idea. if no two speakers on any given amp channel are reproducing the same frequencies at the same time, then there is no drop in impedence for the amplifier (example a 4 ohm midrange, and a 4 ohm sub, properly crossed over/filtered, will represent a total combined 4 ohm load to the amp. 2 4 ohm subs in parallel on the amp will produce a 2 ohm load.)
if you use an electronic crossover, this goes between the head unit and amps, however this is used when a separate amp is used for each "set" of speakers "say an amp for the subs, an amp for mids/highs or 4 channel amp for fronts/reaars)
this way only specific frequencies are sent to each amp.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
