Clarion SRK5 center channel spk
gtchida
Copper - Posts: 89
Posted: November 07, 2003 at 9:10 AM / IP Logged
Wanted to know if anyone has had experience with the Clarion SRK5 center channel speaker.
DYohn
Platinum - Posts: 10,741
Posted: November 07, 2003 at 11:23 AM / IP Logged
This is the self-powered 1/2DIN unit?  Yes, I've installed a couple of them and they work great for a 5.1 system.  Surprisingly nice sound quality and good built-in processor to create a center channel in a standard stereo setup.
gtchida
Copper - Posts: 89
Posted: November 07, 2003 at 11:30 AM / IP Logged
Thanks for the reply - if i installed it with a 2 way electronic crossover in a two amp system,  would you connect it directly to the head unit?
Gary
DYohn
Posted: November 07, 2003 at 4:37 PM / IP Logged
It's designed to go in line with the front channel line outputs.  Connect the RCA's from the head unit to the center channel, then there is an RCA loop-through that goes to your front channel crossover and amp (if you use one.)  The center channel has it's own crossover and built-in amp. The unit is designed to mount in the dash under the head unit in a 1.5 DIN opening.
