03' gm suv's
birdondubthreez
Member - Posts: 21
Posted: November 20, 2003 at 11:27 PM / IP Logged
Any one know how to turn the radio off after the remote start turns off besides telling the customer to leave it off before they get out of the car. Same applys to a 03' ford diesel. THANX
BiRdOnDuBtHrReEz
Metra Tech
Copper - Posts: 125
Posted: November 21, 2003 at 10:05 AM / IP Logged
   The easiest way I would guess would be not to power up the accessory wire. You do not need this wire to make the system work. The ac and heat at are on ignition circuits.
birdondubthreez
Member - Posts: 21
Posted: November 21, 2003 at 12:03 PM / IP Logged
On all of the 03 gm suv's the brown wire does not control the radio it is you can leave the brown and the orange disconected and the radio will still power up. It is a class 2 databus system with no switched. Not hooking up a accesory will not work.
BiRdOnDuBtHrReEz
avxtech
Member - Posts: 35
Posted: November 21, 2003 at 12:38 PM / IP Logged
You need to pulse the drivers door latch wire on shutdown , to simulate the customer leaving the car.
hope this helps
birdondubthreez
Member - Posts: 21
Posted: November 21, 2003 at 12:40 PM / IP Logged
But wont that make the alarm think that the door is open and go off. Do you have a diagram. Have you done this yet? THANKS
BiRdOnDuBtHrReEz
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
