High efficiency speakers
luxuryrules
Copper - Posts: 102
Posted: November 21, 2003 at 8:33 AM / IP Logged
Long time no post... I've got a question for you guys.  The next system I build I'd like to try using high effiency speakers all around.  I've checked out a bunch of brands,and they are all rated at 87 or 90.  Does anybody know of companies or speakers that go over 90?
I refuse to tiptoe through life only to arrive safely at death.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: November 21, 2003 at 10:37 AM / IP Logged
Are you talking about high frequency drivers, or subs?  If the former, HLCD's.  If the latter, Phoenix Gold Cyclone.
But I will let you know one thing on the subs.  Hoffmans Iron Law states that you can have two of the three, but never all three of the following; high output, small enclosure, or high efficiency.  So if you want high output and high efficiency, expect the enclosure size required to be very large.  This will also be true for mids if you decide to put them in sealed kick pannels.
luxuryrules
Copper - Posts: 102
Posted: November 22, 2003 at 7:25 PM / IP Logged
I was talkin about drivers.  At the moment, I've got Pioneer coaxes all around.  I'm planning on adding a 4 channel amp and going to 6.5" components all around on my next revamp.
Thanks.
auex
Platinum - Posts: 5,041
Posted: November 22, 2003 at 9:18 PM / IP Logged
High efficiency speakers = Oxymoron.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Steven Kephart
Posted: November 23, 2003 at 12:51 AM / IP Logged
How does a sensitivity of 106 dB sound?  That is the sensitivity of HLCD's I mentioned earlier.  Here's some links to a couple manufacturers:
http://www.illusionaudio.com/illusion/Driversx.html
http://www.imagedynamicsusa.com/website/products/horns.html
luxuryrules
Copper - Posts: 102
Posted: November 23, 2003 at 10:17 AM / IP Logged
I had done a search earlier and found the imagedynamics site - the specs on their 6.5 components are listed as 90 dB.
But I've found a dealer for the illusion audio and I'm gonna check out those illusion audio ones next week.  Thanks!
DYohn
Platinum - Posts: 10,741
Posted: November 23, 2003 at 10:33 AM / IP Logged
Your first important step is getting rid of those Pioneer Coaxials.  Almost anything you replace those with will sound better!  As far as high-efficiency 6.5" component sets with 90db sensitivity and up, you'll have to spend some money, but the Boston Z series, Infinity Kappa Perfects, CDT Eurosports, Diamond Hex series, a/d/s 2-series, and more all have greater than 90 db sensitivity ratings.  Go to a good high-end shop and look around and test listen a few sets.
luxuryrules
Copper - Posts: 102
Posted: November 24, 2003 at 8:40 AM / IP Logged
The Pioneer coaxes sounded great - for about a year.  I'm revamping because now they rattle (guess they're blown, but I've only been pushing them with the HU at relatively low volumes).
I've visited some dealers and I've narrowed my favorites to the Kappa Perfects, the HLCDs, and Hexes.  Now, my HU is pushing 22wpc RMS, and when I add an external amp I'll probably get one of the Alpine 40x4 amps.  Of those speakers, which ones will resist blowing out on me the most?  As you can see I'm not planning on pushing them hard, but I didn't push the Pioneers that hard either...
DYohn
Posted: November 24, 2003 at 10:04 AM / IP Logged
Just make sure you are not driving your amp into clipping.  A head unit with 22wpc can be easily driven into clipping and that can fry a voice coil, especially of a tweeter.  If your speakers are "rattling," however, I would suspect a woofer cone or surround is gone.  Pioneer = generally cheap construction, so I am not surprised and it probably had nothing to do with your amp.
I don't know the HLCDs, but I really like the sound of both the Kappa and the Hex.  Diamond has a much better high end with smoother sounding tweeter, and the Infinity has better low to mid bass.  You can't go wrong with either, so get the ones that sound the best to your ears since you are the one who will have to live with them.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
