03 envoy subs/amp in, chime out?
noalibi
Member - Posts: 13
Posted: December 04, 2003 at 11:52 PM / IP Logged
got subs/amp setup in bro-in-laws 03 envoy. everything went smooth except now he says the chime does'nt work. asked him if he checked fuses, and he said "not yet", but he does'nt really care if it works (nuisance to him.
just wonder if the install had anything to do with this condition (read something about this in old post once).
only tie in to factory unit was a line level converter after the factory amp and turn on lead tap. anybody?
Stevolon
Member - Posts: 28
Posted: December 05, 2003 at 9:48 AM / IP Logged
what did you use for amp turn on?There is no acc wire at the hu.I am assuming you left the factory hu in.
Steve@A.E.S
noalibi
Member - Posts: 13
Posted: December 05, 2003 at 12:35 PM / IP Logged
pickup up a turn on at the fuse panel under the rear left seat. found one that would be hot on acc. and ign., but i don't remember which fuse it was. was a 25 amp fuse though. if you need to know i can look next time he comes over.
si90lude
Member - Posts: 24
Posted: December 06, 2003 at 3:21 PM / IP Logged
as far as the chimes go, newer chevys use the factory stereo to "play" the chimes. To retain this feature you must do one of 2 things, there is a "T" harness available that keeps th factory radio in the car (you can usually put it under a seat, in trunk etc...). also there is an adaptor that goes behind the dash that is really cool (but pricey) cause it gives you an acc turn on.
noalibi
Member - Posts: 13
Posted: December 08, 2003 at 8:10 PM / IP Logged
okay, so where do i buy these components?
richs
Member - Posts: 37
Posted: January 18, 2004 at 12:57 PM / IP Logged
www.soundgate.com has a module called the GMCHIME which prevents you from having to relocate the radio. It will product the chimes and keep the BCM happy. It also monitors the class 2 bus and provides you with a switched 12volt output.
Best Regards,
Rich
customsuburb
Gold - Posts: 1,813
Posted: January 18, 2004 at 6:52 PM / IP Logged
Go to www.crutchfield.com and go to car audio and video instalation. In the reciever instaltion category click on factory system integration. they should have it there. They also have onstar and bose integration interfaces I think.
CruisinS&S
Copper - Posts: 225
Posted: January 18, 2004 at 8:58 PM / IP Logged
go2pac.com
they have the best interfaces!!
Cruisin Security And Sounds
