98 explorer, adding subs with LOC
eld101
Member - Posts: 43
Posted: December 06, 2003 at 2:01 PM / IP Logged
Im working on a 98 explorer. Adding subs using a line output converter. We tried tapping after the sub amp but it kept melting the cponverter because it was over 80 watts of power. We have most of the right side panel off and see 5 wires going into the amp, I assume 2 signal, power, ground and turn on....
Which 2 can I tap for signal!
Thanks!
eld101
Member - Posts: 43
Posted: December 06, 2003 at 2:02 PM / IP Logged
I forgot to mention, it has a factory sub and amp(thats the amp with the 5 wires going to it.)
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
