8 guage power/ fosgate 451s
crewdog10
Member - Posts: 8
Posted: December 24, 2003 at 7:02 AM / IP Logged
Do you guys thinks that an 8 guage power wire will be suitable for a fosgate 451s? I just bought a new amp and I would rather not replace my power wire. The fosgate has a 4 guage input, but this is the only amp that I'm running. My power wire is probably less than 10 ft. because it leads under the passenger seat. Any suggestions are greatly appreciated.
Geeque
Silver - Posts: 310
Posted: December 24, 2003 at 9:12 AM / IP Logged
What specs does the amp call for, amp draw?
Gary Kline
MECP Master Technician
Platinum - Posts: 12,488
Posted: December 24, 2003 at 9:34 AM / IP Logged
Use this link : https://www.the12volt.com/info/recwirsz.asp and calculate what is needed for your power wire and ground.
pureRF
Silver - Posts: 619
Posted: December 24, 2003 at 8:47 PM / IP Logged
I'm sure you will be fine with an 8 as long as its about 10 ft.
dream it, build it, fiberglass it
pureRF
Silver - Posts: 619
Posted: December 24, 2003 at 8:51 PM / IP Logged
I just checked it out and the amp calls for an 8 gauge, not a 4 so you will def. be able to run an 8 gauge
