High Current Amp ?
carguy411
Silver - Posts: 683
Posted: December 27, 2003 at 10:39 AM / IP Logged
ok im doing a system in my friends BMW 3series
now im are going to put either 2 or 3 10JLW6's in the back and were looking for a good amp to push them
now first question
-- does a high current amp require that you change the altenator???
--what amp would you recomend to push theses subs to get full power from them???
pLEASE LET ME KNOW
THANKS
auex
Platinum - Posts: 5,041
Posted: December 27, 2003 at 12:00 PM / IP Logged
It really depends on the amp and its current draw as to whether you need to up the alternator. The amp is going to be the second or third thing to think about in the car, the first two things should be the box design and how you are going to get the sound into the cab of the vehicle.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jeffchilcott
Platinum - Posts: 2,483
Posted: December 27, 2003 at 12:31 PM / IP Logged
If i was looking to design a jl system, which i love jl products. I would recomend 2 10 jlw6v2's   instead of 3 jl w6's   you will be alot happier with the sound quality and spl levels. As far as an amp i have hooked up 2 of these sub config's ina vented box to a rockford 800a2 and it sounded very nice, it was able to push 148.8 in a standard car. and 151.3 in a hatchback with some power mods basically a 5 farad cap and a yellow top under the hood..let me know if you need help with the box i do still have spec's for these boxes
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
carguy411
Silver - Posts: 683
Posted: December 27, 2003 at 12:44 PM / IP Logged
yeah i told him to too go with the w6v2 but he has the w6 already thats y he wants to keeep them
als o im going to have the subs fire in to the car from behind the seats
also if u can help me design a box that would be kool.
im not to sure what amp he wants to get but if u have a good suggestion please let me know
thanks
jeffchilcott
Posted: December 27, 2003 at 12:54 PM / IP Logged
i wouldnt recomend firing the subs into the car, with a vented or ported box it is best to let the repercussion off the trunk lid return to inside the car i will try to draw up a box and post today
2007 World Record
carguy411
Silver - Posts: 683
Posted: December 27, 2003 at 2:36 PM / IP Logged
ok then what if i hvae them fire to the trunk and put a plexi glass back on them so you can see the magnets how thick would the plexi have to bee??
also the box you are going to draw will it fit tight against the seat ina 02 bmw 3 series
also if you could maybe email me the plans and letme know some otheroptions i might have
thanks
bboy411@aol.com
jeffchilcott
Posted: December 27, 2003 at 3:36 PM / IP Logged
I would go with a 3/4 or 1 inch plexi..but plexi gan be expensive if you are buysing sheets from stores like home depot, try to find some old boxes for salvaging plexi, try local pawn shops they normally have boxes laying around if you cant find any i can get a good sheet off an old box for you
2007 World Record
carguy411
Silver - Posts: 683
Posted: December 28, 2003 at 12:31 AM / IP Logged
only thigi really want to clear up is how much of a difference will firing the subs in to the car and in to the trunk make a difference in sound and quality byt hat much???
thanks
carguy411
Silver - Posts: 683
Posted: December 28, 2003 at 5:02 PM / IP Logged
ok i made a little mistake he had told me that he had w6's but i looked today and he has the w0's 4 ohm
now im thiking of using 3 of them facing the trunck which amp and box size do u recomend now
also remember u said dont face them into the car.
i had this crazy i dea that face 2 subs to the trunk and 2 subs facing the inside would the y cancell each other out
tell me what you think
thanks
Durwood
Copper - Posts: 126
Posted: December 28, 2003 at 6:57 PM / IP Logged
Well, the 10W0-4 ohm model can handle 125 Watts RMS power each.  They're single-voice coil, so the only configuration that really makes sense is to parallel them all together for a 1.33 ohm load.  You need an amp that's 1-ohm stable and puts out 200-675 Watts RMS.  With the relatively low sensitivity of the 10W0-4 (85.5 dB/W-m), I'd tend towards the high end of that range.  A 2-ohm stable amp might work with a 1.33-ohm load, if the amp is rated conservatively.  I think JBL has a 600-watt mono amp that's 1-ohm stable, and there are probably several other brands/models as well.
Scott Gardner
