wiring sub amp
hamrajw
Member - Posts: 41
Posted: December 29, 2003 at 2:03 PM / IP Logged
I have a head unit that has front and rear preouts, but no subwoofer preouts. I wanted to hook up a sub amp. Can I use the rear preouts for the sub amp, while leaving the front and rear speakers connected to the speaker out wires from the head unit.
Thanks for your help.
mobile E
Copper - Posts: 217
Posted: December 29, 2003 at 2:14 PM / IP Logged
yes you can do that, but i reccomend you have a remote bass control  or you will have  no way of adjusting just the sub powerwiring sub amp -- posted image.
everything stolen :(
Workin on a new system :)
Peace in the middle east
jeffchilcott
Platinum - Posts: 2,483
Posted: December 29, 2003 at 2:19 PM / IP Logged
have you considered gettin an eq? nmost eq's will take one set of rca inputs and then will devide to one front set one rear set and a sub set, then you can adjust you bass that way
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
hamrajw
Member - Posts: 41
Posted: December 29, 2003 at 2:39 PM / IP Logged
Thanks for the quick replies.
Can I just use the front and rear speaker outs (both left and right for each) for the internals and in addition to that, use the rear preouts for the sub? Or would that draw too much power from the head unit? Would I be able to control the bass level from the amp, or do I need an additional remote bass control?
If I decided to get the eq, to get a signal to my internal speakers, would I need to amp them?
forbidden
Platinum - Posts: 5,354
Posted: December 29, 2003 at 2:40 PM / IP Logged
He's probably better off buying an amp that has a remote level control that comes with the amp as well as an RCA pass through, this way he still has front and rear pre-outs. It is also one less piece of equipment to install, one less potential noise problem, less $ to spend..... but yes an EQ will also still work, as would an outboard crossover.
jeffchilcott
Posted: December 29, 2003 at 11:18 PM / IP Logged
you dont need to buy an amp for your internals when useing the rca's on most radios, if you go with the eq use your rear out, to run to the eq, then run a sub out off that. later you will be set up for when your ready to run your internals off an amp
2007 World Record
hamrajw
Member - Posts: 41
Posted: December 30, 2003 at 10:10 AM / IP Logged
Thanks for all the help guys.
I decided to buy a Bazooka powered tube. It was on sale at CircuitCity. Hopefully it does the job.
hamrajw
Member - Posts: 41
Posted: January 04, 2004 at 9:29 AM / IP Logged
I took the tube back and got the Bazooka ELA500.1 amp to power my 2 Infinity subs. I should finish the install this weekend. Thanks for the assistance. I'll let you know how it comes out.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
