cap size
martyapo
Posted: January 13, 2004 at 2:03 AM / IP Logged
What size cap should I use? I'll be running the Bazooka rsa75.2 amp into two 10" bazooka subs at two ohms. The amp's stated rms is 600 x 1 at 2 ohms, though the subs are rated 200 rms each. I don't think I'll be maxing out the amp for fear of blowing the subs, I just wanted the extra headroom. Will a .5 cap do the job, or spend twice the money, :( ,for a 1 farad cap. If I see a need to, can't I add another cap later? The cap I was considering buying is a Phoenix Gold. Are these good caps? Any help would be great, thanks.
martyapo
Posted: January 13, 2004 at 10:18 AM / IP Logged
P.S. .... will using a smaller cap than suggested prevent  power from reaching my amp? In other words, will a .5 farad cap let only enough power pass through my amp to output 500watts?
mobile E
Copper - Posts: 217
Posted: January 13, 2004 at 12:13 PM / IP Logged
the general rule is a farad for every 1000 watts, if you dont stick by this rule it defeats the purpose of doing something right the first time, but its better to have a cap than no cap
everything stolen :(
Workin on a new system :)
cap size -- posted image.
Peace in the middle east
italnpimp59
Silver - Posts: 427
Posted: January 13, 2004 at 1:23 PM / IP Logged
i would recommend getting the 1.0 farad cap.  and yeah phoenix gold is a good cap.  anything they make is good
Clean Install
Silver - Posts: 446
Posted: January 14, 2004 at 5:51 AM / IP Logged
I would also suggest getting a 1 farad cap,
If we learn from each success and
each failure, then we can improve ourselves
cavyman
Copper - Posts: 88
Posted: January 14, 2004 at 12:37 PM / IP Logged
1 Farad Cap will do the trick.  And you really cant go wrong with Phoenix Gold, but any type of cap will normally run the same.  The brand name will make the price go up though.
1 plus 1 equals 2
