extra amp?
xTimx
Copper - Posts: 354
Posted: January 18, 2004 at 1:33 PM / IP Logged
i have 3.5 MB quart mid's for fronts and rockford 6x9's for rears...when i had my 94 cavalier they were hooked up straight to the deck (jvc (KD-LH1150) they sounded great and all and there wasnt any distortion. but i totalled off my car and i bought a 91 cavalier z24 and again i installed them into my car but when i hooked them up and played them one of the 6x9's had blown. lucky i had another set of 6x9's on hand. but the thing is i had my system in the 94 cavalier for a long time and had no trouble. do you think i should get an amp, if so, how much wattage.
p.s. the 6x9 doesnt seem to be blown, when you push the cone up and down it moves with no noise as if the voice coils arent touching the magnet. could it be soemthing else!?
staudio
Member - Posts: 41
Posted: January 18, 2004 at 3:04 PM / IP Logged
double check your connections. If it all seems well hook the other set of 6x9's up and see if you get the same problem. If the other 6x9 doesn't produce any problems than there's probably something wrong with the 6x9 that seems blown such as a bent voice coil (possible bottom out) or a separation somewhere in the spider, cone, voice coil attachment.
xTimx
Copper - Posts: 354
Posted: January 18, 2004 at 6:25 PM / IP Logged
ok but what about the amp situation then!?
DYohn
Platinum - Posts: 10,741
Posted: January 18, 2004 at 6:45 PM / IP Logged
IN GENERAL, if your head unit has four powered outputs (left and right, front and rear) then it will power four speakers.  That's what it is designed to do.  If you want to run more than four speakers, or if the HU output is not enough for your taste, then you need another amp.
A speaker may seem to move OK and still be blown.  The voice coil can be electrically bad.
jeffchilcott
Platinum - Posts: 2,483
Posted: January 18, 2004 at 10:07 PM / IP Logged
crazy adivse...looking for a cheap decent sounding amp, look at volfenhag....I sell their 800 watt 4 channel 50x4rms 4 ohm....for $130   and they really are decent amps when they first came out we put one through a tourture test to see if we could blow it up, and surprisingly we couldnt...the channels are 2 ohm stable, and we have been runnin one amp at 2 ohm on all 4 channels for over a year now without a problem yet!
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
xTimx
Copper - Posts: 354
Posted: January 19, 2004 at 1:23 AM / IP Logged
keep in mind that i live in saskatchewan canada and we bushiens havent heard of that kind of product! :P
cavyman
Copper - Posts: 88
Posted: January 20, 2004 at 1:24 PM / IP Logged
You really dont want to underpower your speakers.  In the long run, it might not be good for them and also why spend the money on a good set of speakers if you arent gonna get the best possible sound from them?  Why not spend $150 on a decent 4 channel amp?  You will not regret this.  More power=better sound.
1 plus 1 equals 2
xTimx
Copper - Posts: 354
Posted: January 20, 2004 at 1:30 PM / IP Logged
well i come to this conclusion! i blew my rockford 6x9, so i'm replacing them with MB quart 6x9's ( i think two-way) then i'm getting a RF, 551x to power them! so i'll have MB quart 3.5 and 6x9's being powered by my RF 551x.
xTimx
Copper - Posts: 354
Posted: January 20, 2004 at 10:22 PM / IP Logged
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
