what amp
Mrjoel
Posted: August 06, 2002 at 1:07 AM / IP Logged
hey i have a pioneer 600w max  300w nominal sub . what amp should i use
how many channel and how many watts .
thanks
wvsquirrel
Gold - Posts: 1,237
Posted: August 06, 2002 at 2:21 AM / IP Logged
My preference is Rockford Fosgate, but it all depends on what you're willing to pay for.  I'm not a professional, but I've always been told to keep the RMS (nominal) levels close to the same for both the amp and sub for best performance.  You need to post the model number of the woofer if you have it, how many ohms the sub is, as well as if it is a single voice-coil or dual voice-coil.  These all play a role in choosing an amp
-WVSquirrel
Mrjoel
Posted: August 06, 2002 at 3:12 AM / IP Logged
ok it is the pioneer ts-w304c 12inch
  • Foamed IMPP (Injection Molded Polypropylene) Rigilite Composite Cone Woofer
  • Dual-Layer Urethane Surround
  • Direct Bobbin Mounted VCCS (Voice Coil Cooling System)
  • Conex Damper with Damper Ring
  • Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
  • Projected Pole Yoke with Vented Pole
  • High-Energy Ferrite Magnet with Bumped Back Plate
  • Mrjoel
    and its 4 ohms
    wvsquirrel
    Gold - Posts: 1,237
    Posted: August 06, 2002 at 3:47 AM / IP Logged
    If I were looking..... I'd go with one of these 3
    Rockford Power 450S ..... 450 watts x 1 @ 4 ohms bridged RMS
    Rockford Power 500.2 .... 500 watts x 1 @ 4 ohms bridged RMS
    Rockford Power 500bd ... 300 watts x 1 @ 4 ohms RMS
    Not exactly sure of all the prices, but I picked up a new 500bd for $460 (full retail is around $540).  The 500bd is a Mono amp, and is also 2 ohm stable.  Which means you could get another 4 ohm sub and wire it in parallel, then it becomes 600 watts x 1 @ 2 ohms RMS.  Which is still only 300 watts per sub... but now you're running 2 subs from the same amp, at double the original wattage of the amp, for meerly the cost of another sub.  There are always other ways to go, this was just one of them.............
    Which ever way you choose, I would not go under 300 watts or over 500 watts
    Squirrel
    "No more Cpt. Kirk chit chat"
    Donate to the12volt.com
    Mrjoel
    Posted: August 06, 2002 at 5:35 AM / IP Logged
    cheers
    rockfordfossie
    Member - Posts: 25
    Posted: August 06, 2002 at 10:01 PM / IP Logged
    Go with this amp it'll deliver a 4ohm output of 300 watts rms and I got it for only $107 dollars delivered to my house here's the link
    http://www.proactiveelectronics.com/
    serch for "Power Acoustik" at the top and look for
    Power Acoustik OV2520 Car AMPLIFIER
    on the second page of search results and look it over
    I just installed mine it's loud clear and looks really good in my car.
    send me an email at ineedsubs@hotmail.com if ya get it and install it tell me if you like it
    ZX2's KICK A $ $
    Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
