99 explorer
mbiker1
Member - Posts: 37
Posted: February 07, 2004 at 6:42 PM / IP Logged
how do you take apart the bezel around the cd player and which wires are the +and - for the left and right front speakers
customsuburb
Gold - Posts: 1,813
Posted: February 07, 2004 at 7:28 PM / IP Logged
front left: + ORANGE / light green   - light blue/white
front right: + dark GREEN/ orange  - WHITE/ light green
rear left: + gray/light blue  - tan / YELLOW
right rear: + ORANGE / red  - BROWN / pink
forbidden
Platinum - Posts: 5,354
Posted: February 07, 2004 at 7:29 PM / IP Logged
Drawing a blank right now, sorry... check for 2 screws above the factory radio and 2 screws under the radio. Some Ford bezels actually just pop off with a little gentle pressure, this may be one of them. For the speaker wires you will need to determine if it a amplified system or not, if it is the hidden amp can be found behind the passenger side rear seat, behind the panel. If it is not amplified, check www.installdr.com for wiring color codes. If the plugs are basically the same size and shape, just different colors, the installdr. site will be correct for wiring.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
