03 Mitsubishi Galant install question
MBZ oe
Silver - Posts: 385
Posted: February 13, 2004 at 6:56 PM / IP Logged
I am going to install a head unit, amp, and subs in a friends 03 Galant this weekend. I was wondering if anyone who has done an install in one has found anything unexpected or any problems? It has no premium sound system so I don't think it has a factory  amp, but I will be using the factory speaker wire with the factory speakers for the time being.
TIA for any help
A.
boom, boom, boom boom....
forbidden
Platinum - Posts: 5,354
Posted: February 13, 2004 at 7:04 PM / IP Logged
Sorry I can't help you, Mitsubishi cars are rare around out parts, a F350 though, different story
MBZ oe
Silver - Posts: 385
Posted: February 13, 2004 at 7:12 PM / IP Logged
Thanks Forbidden. I'm still waiting for my new head unit to arrive for my ride. It'll be here on monday. What kind of resistor would I need to splice in my brake line if I can't get rid of the pop noise from stepping on brake?
A
forbidden
Posted: February 13, 2004 at 7:14 PM / IP Logged
Not a resistor, a cap. I don't think it will or should be an issue with the new deck. (crosses fingers)
auex
Platinum - Posts: 5,041
Posted: February 13, 2004 at 7:37 PM / IP Logged
Cake walk. Take the dash bezel off, lower the ac controls, there will be 1 screw at the back of the radio, then lift the tabs out of the front of the radio and it will slide right out. There is a spot on the driver's side firwall that you can drill out easily, clutch pop-out. Then everything else is simple.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
