CD player in 1990 Dodge Caravan
band13
Posted: February 22, 2004 at 9:53 PM / IP Logged
I have a 1990 Dodge Caravan and i need help installing my new CD player.  I have found out that the wiring is different colored, and i cant find the power or the ground wire.  If you can help please do!
forbidden
Platinum - Posts: 5,353
Posted: February 23, 2004 at 2:44 PM / IP Logged
Does your vehicle have the infinity sound system?
Metra Tech
Copper - Posts: 125
Posted: February 24, 2004 at 10:05 AM / IP Logged
I can't help you on the power wire if you are not using a wiring harness, but the ground is the braided cable  that was bolted to the back of the radio.
thepencil
Gold - Posts: 1,526
Posted: February 24, 2004 at 12:08 PM / IP Logged
This is the diagram that may help you out with identifying the wire you are looking for. For the powers wire it should be pink/black, but the best bet is to use a multi-meter to test out the wire. As mention by Metra Tech the ground wire is "the braided cable that was bolted to the back of the radio". If you don't find that wire you can attach the ground wire to any metal part of the car body.   I hope this helps you out.
Be careful whose advice you buy, but be patient with those who supply it.CD player in 1990 Dodge Caravan -- posted image.
band13
Posted: February 25, 2004 at 9:32 AM / IP Logged
Thanks you guys. and thanks "thepencil" for that diagram! Now i can put my cd player in! Thanks
Tuesday, May 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
