are these good subs?
BangBang
Silver - Posts: 287
Posted: February 29, 2004 at 6:43 AM / IP Logged
http:///.com/dll?ViewItem&item=3080577794&category=3291&sspagename=STRK%3AMEBWA%3AIT&rd=1
i need ur feedback quick there about to end!
better than sony xplod 1100 watt max peak?
auex
Platinum - Posts: 5,041
Posted: February 29, 2004 at 8:58 AM / IP Logged
They are alright subs.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
soccer_aholic
Copper - Posts: 71
Posted: February 29, 2004 at 4:29 PM / IP Logged
Ok these subs are ok. if you are looking into buying something not to expensive these would be good. The Sony's are Crap. the rockfords are much better quality. Although they handle much less power i would go with the Rockfords. In the past i have had much trouble with sony subs. i don't think i will every buy sony subs again.
Soccer_aholicare these good subs? -- posted image.
BangBang
Silver - Posts: 287
Posted: February 29, 2004 at 4:33 PM / IP Logged
well ok thanx alot. i'll see if i can get them for cheap!! thanx. i dont make much so yeah!
if u know where i can buy some good quality subs for a low price letme know. also i'm looking for a distribution block thanx!
soccer_aholic
Copper - Posts: 71
Posted: February 29, 2004 at 4:41 PM / IP Logged
Yeah i am sure you could find some really cheap on ebay. also whenever i am looking for wiring or fuses etc. I go to sounddomain.com they will have distribution blocks and they are normally cheaper then your average retail store
customsuburb
Gold - Posts: 1,813
Posted: February 29, 2004 at 6:09 PM / IP Logged
Here are some for the same price as the ones you found on ebay. You get manufactures warranty though since its from crutchfield. 2 for $99 is a pretty good deal. Rockford Fosgate subs This is the cheapest distrobution block I could find and it should work fine: Distrobution block. Make sure to get the right fuse sizes in it for your amps though!!!
specialblendj
Copper - Posts: 118
Posted: March 01, 2004 at 11:03 AM / IP Logged
I'd go with some Alpine type-R's if your on a budget.  they are comparable subs that you can find on ebay for about 90 bucks Buy it Now.  They have good SQ and hit pretty hard for under a hundred bucks a pop.
soccer_aholic
Copper - Posts: 71
Posted: March 01, 2004 at 11:29 AM / IP Logged
Oh yeah. Alpine Type R's are NICE. right now a friend is running two 12inch type r's off an alpine MRD-M500. and WOW. they are about twice the price of those rockfords but yeah if you have the money go with one or two of those. You will be pleased. when going for quality go with alpine
customsuburb
Gold - Posts: 1,813
Posted: March 01, 2004 at 6:44 PM / IP Logged
uhh guys he said he wanted some low priced subs. Buying two type R subs would be twice as much as he plans on spending.
