1997 Mitsubishi Montero Factory Amp Location
lagatbezan
Copper - Posts: 117
Posted: March 06, 2004 at 12:50 PM / IP Logged
Hi,
anyone know where the factory amp is located in a 97 mitsubishi montero?
Metra Tech
Copper - Posts: 125
Posted: March 07, 2004 at 10:33 AM / IP Logged
Behind the rear right panel above the wheelwell. Why do you need this information?
lagatbezan
Copper - Posts: 117
Posted: March 07, 2004 at 10:38 AM / IP Logged
well, to change the radio in this car, i needed to bypass the amp since there are only 3 wires going to the stock radio!
thanks for the info, i ended up running new wires anyway to each speaker.
Metra Tech
Copper - Posts: 125
Posted: March 07, 2004 at 10:49 AM / IP Logged
That's why I was asking. I was going to tell you that my company has a wiring harness just for this vehicle to allow you to use the factory amps and not have to run any wires. It is Metra part# 70-7003. It uses the DIN plug for preamp signal to the amps.
lagatbezan
Copper - Posts: 117
Posted: March 07, 2004 at 11:03 AM / IP Logged
i do carry metra products, but that part is not listed on the catalog or online! if its listed online, can you tell me where?
but now i know... thanks for the info.
Metra Tech
Copper - Posts: 125
Posted: March 07, 2004 at 1:33 PM / IP Logged
It is a new part that has only been out for about 6 months. It's too new for the catalog and like most of our special harness', it is not online. That is one reason why I am on this forum. To tell as many people about these time saving special harness'  that I can.
meh66
Copper - Posts: 266
Posted: April 08, 2004 at 10:14 AM / IP Logged
Hi Metra Tech,
   Can you explain a little more about the 70-7003? I was a little confused on your statement of the DIN plug. Are you just telling us that the DIN will be plugged into the factory amp? Do you have a pic of this product? When installing this product do you have to plug this harness into the amp or behing the head unit? Thanks for the info.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
