mono amp or 2 channel
curt234
Member - Posts: 42
Posted: March 10, 2004 at 11:31 AM / IP Logged
I was thinking about getting a bigger amp and go with a mono cause I only have 1 12" sub, but then I was thinking I might get a bigger sub so I might be better off getting a two channel incase I want to run two subs. Question is what sounds better mono or 2 channel and get u bridge the 2 channel to power one sub until maybe u decide to run 2 subs? Which one would u got for?
cheagreen
Copper - Posts: 62
Posted: March 10, 2004 at 12:06 PM / IP Logged
A monoblock amp doesn't sound "better" than any other amp. It just was designed to power one sub. But with wiring flexibility, we can wire 2 subs on a monoblock amp. How many ohms is your sub, and the one your planning to get? If you can, get matching subs. Go with a mono amp.
Head Unit:Pioneer-Deh-1600
Fronts:Kicker 6x8 S57's
Front Amp:Coustic PowerLogic Amp460
Rear Fill:Stock 6x8's
Subs: 2 10" JL Audio W3's
Sub Amp: JBL bp600.1
Wiring: KnuKonceptz
curt234
Member - Posts: 42
Posted: March 10, 2004 at 12:25 PM / IP Logged
I have a pioneer 12" Since I looking for a truck I not going to buy anything cause the big box I got know won't fit so I guess I wait till I figure out what I am going to get.
Mono for subs is the way to go hey cool. How would u wire it with two subs?
forbidden
Platinum - Posts: 5,354
Posted: March 10, 2004 at 2:21 PM / IP Logged
You must determine the subs first, then armed with these subs it can and will determine the wiring configuration to the proper mono amplifier.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
